Turbo on Allen's 686
SuperCmore
09-28-2004 07:52:05
Hey Allen, can you put a turbo on that nice looking 686?? Then it would really fly with that Massey Flop Over Plow!! Anybody ever put a turbo on a 310?? Cmore
BigRed
09-28-2004 12:27:20
 Re: Turbo on Allen's 686 in reply to SuperCmore, 09-28-2004 07:52:05
Had a 686 with the 312 diesel. Not a bad machine. Now I have a 756 with a turbo on the 310. It puts out some pretty decent power, but it has a much heavier rear end. Another thing, the turbo has been on the tractor since it was new, and it seams that tractors can handle that much better than putting one on it when the tractor is 25 years old.
Allan in NE
09-28-2004 12:45:10
 Re: Turbo on Allen's 686 in reply to BigRed, 09-28-2004 12:27:20
BR,
I agree. I think IH knew what they were doing when they crossed over to that bigger system in the higher horsepower tractors.
Just makes sense to split that load out over more area.
Allan
Aces
09-28-2004 10:33:26
Allen I not saying put a turbo on your 686 put that rear end will handel a 234 corn picker better than a 560 your 6 row planter may be to much. I know of a 656 gas that had no troble staying wit a 4020 wit 4-16 plow and the 656 with 4-14 plow it had no troble wit the 4-16 plow in 6000 hrs one TA job and new bolts in the differencial case.
Allan in NE
09-28-2004 10:53:32
 Re: Turbo on Allen's 686 in reply to Aces, 09-28-2004 10:33:26
Thanks Aces,
Not to worry 'bout a blower on this one. I'm not puttin' another nickel in this old tractor..... Well, unless of course, she should happen break down.
There's a limit to everything.....and this old gal has already reached her “nickel & dime me to death” threshold long ago. :>)
Allan
Allan in NE
09-28-2004 08:10:59
Hi Cmore!
Heck, I dunno.....
I'm wondering if the rear end could even handle it; they are pretty scrawny the way it is.
I plan on just using the 686 for a cultivator tractor and maybe making a little hay; it really isn't big enough for field work to any extent; doubt if it will even pull a packer.
Also, I don't think it is big enough to even handle a 6 row mounted planter, is it? Never tried this sized tractor on a heavy planter, so don't know.
Thanks for the hollar,
Allan
steveormary
09-28-2004 10:31:14
 Re: Turbo on Allen's 686 in reply to Allan in NE, 09-28-2004 08:10:59
Allan;
A book I have rates a 686 diesel at 8000lbs and +60hp. Seems hp should be more then that. Should handle a 6 row pull type planter. Dont know about mounted. And depending on size of packer(not sure what that consists of)it should handle that ok. Now about the plow, You should atleast be able to pull it down the road. My 706 german would pull a 4-16 semimount fast hitch IH plow in 4 and low. Same with a 15'MF tandem disk with bar harrow. 4 and low for the most part.That would usually give me an easy 4.5mph.
Hope all works out for you and you can get back on the farm.
steveormary
Allan in NE
09-28-2004 11:06:10
 Re: Turbo on Allen's 686 in reply to steveormary, 09-28-2004 10:31:14
Mornin' Steve,
Yes, I think you hit it right on the head. I think this one is somewhere's about 62 to 64 horse and it tips the scales right at 9100 lbs. 'Course when I get down outta these hills, I've got to get that fluid out of those rear tires and buy a set of clamp ons.
I'm pretty sure it will handle this 14.5' disc to knock down stalks and I will also be able to use it to pull a 15' 3-point rotary hoe.
Thanks for the words of encouragement, we are darned sure gonna get out there again, or by golly, take our very last breath a tryin'. :>)
Allan
steveormary
09-28-2004 19:57:16
 Re: Turbo on Allen's 686 in reply to Allan in NE, 09-28-2004 11:06:10
Allan, Thats the spirit.
steveormary
