Farmall 240 steering
James Davis
09-28-2004 13:16:04
Couple questions: Is there an good way to get the U-joint off the steering shaft (the first one) under the steering wheel?
Is there a way to adjust the free play in the worm gear?
Thanks.
Thanks, Jim
Al L. in Wisc.
10-01-2004 19:30:45
 Re: Farmall 240 steering in reply to James Davis, 09-28-2004 13:16:04
James, you can rotate the worm gear around as only "half" of it is used.
