Farmall H radiator question.
DT
09-28-2004 14:49:30
Howdy, Im relacing the radiator in my 1950 Farmall H. Im replacing a non presuized radiator with a pressurized one, and new cap. Is there anything else that I need to do so this rad will be ok? Is the waterpump seal the same on both radiator styles? Thanks!
RayA
09-30-2004 18:11:09
 Re: Farmall H radiator question. in reply to DT, 09-28-2004 14:49:30
I had the studs busted/rusted off the bottom of a radiator on and H and had a friend weld a nut to what was left of them and they came out pretty easy. We did have to be careful though because it appears that the solder tried to melt a bit as well, but it is still holding,, hope this helps.
ShepFL
09-28-2004 19:35:59
Anyone got some good ideas on how to repair the stud on the bottom. On my H radiator the studs are busted. I was thinking of making a plate with studs welded to it to remount the radiator.
Thanks in advance
The Red
09-28-2004 15:32:18
You will be fine DT. Temp. between the pressurized and non pressurized is at most 20 degrees difference. That is only an 8 psi pressure at most.
kfox
09-28-2004 15:03:57
If your tractor has the origional temp gauge, it might not read correct. Temperture gauges had a different part # for pressurized and non pressurized radiators.
