Identify M head-#'s welded over
george md
09-28-2004 16:58:56
Have a customer with an M head that he says is
high compression.The area where the numbers should
be has been welded over to fix a crack (and failed) Does anyone know the cc of the combustion chamber
of either regular or a hi comp head ? This one measures 210 cc .If this is not a hi comp head , then it
is not worth removing all of the trash arc weld
and doing a good job with oxy/acet cast iron weld.
Thanks, george
george md
09-29-2004 12:03:26
 Re: Identify M head-#'s welded over in reply to george md, 09-28-2004 16:58:56
Thanks guys , I think I know what it is .
george
DWV
09-28-2004 18:37:18
Check valve length,if its 5-27/32 inch long it would be 8060 or 8574.That is regular gas head for
M or SM.If valves are shorter,low compression.If
valves are longer you have a later head.
george md
09-28-2004 19:57:39
 Re: Identify M head-#'s welded over in reply to DWV, 09-28-2004 18:37:18
DWV, Both ex and intake measure 5.850 to 5.860, I can see what I think is the first digit and maybe the part of the second one .
8 then maybe a 1 , the rest is under the weld,
ends with a C , typical of IH .
george
MagMan
09-28-2004 18:35:41
Are you any where near NY I have two M heads to sell cheap I was told they were good when I bought them no visable cracks. JON
JT
09-29-2004 07:05:15
 Re: Identify M head-#'s welded over in reply to MagMan, 09-28-2004 18:35:41
JON,
are these M heads complete, or are they just bare heads. What do you want for one of them. I will have to pay about 50.00 shipping for this, I live in Central Illinois, but I need an M head. had a guy tell me if I could get him a head, He would give a F20 in trade. F20 in poor shape, but I would like to have one to try to rebuild and get running. If you want to email me.
Jim
MagMan
09-29-2004 07:24:15
 Re: Identify M head-#'s welded over in reply to JT, 09-29-2004 07:05:15
actually I was hoping to trade on or both for an H head I beleve one has valves in it and the other one has valve there but apart they are burried in my building right now. I dont know if they magna flux good I would like to get 50.00 a piece I guess. JON
JT
09-29-2004 07:51:29
 Re: Identify M head-#'s welded over in reply to MagMan, 09-29-2004 07:24:15
JON
If you want to dig one out, I will take the one that is in peices. I will give you 50.00 for it if you will tell me how to pay you for it.
Jim
MagMan
09-29-2004 18:39:32
 Re: Identify M head-#'s welded over in reply to JT, 09-29-2004 07:51:29
Hi Jim Not a problem Give me a email at abuckmaster147@wmconnect.com JON
george md
09-28-2004 19:38:58
magman, Thanks , I'm in Md ,but in the next month or so
I'm going to geneva to seneca falls, and cross lots to hancock and home. Mother lives in seneca falls. where are you in NY , I'll uncover the email.
george
randy hall
09-28-2004 18:01:51
that should make it a gasoline head.
george md
09-28-2004 18:09:34
 Re: Identify M head-#'s welded over in reply to randy hall, 09-28-2004 18:01:51
Randy, No doubt it's gas but which one ?
george
rustyfarmall
09-28-2004 18:21:59
 Re: Identify M head-#'s welded over in reply to george md, 09-28-2004 18:09:34
There were only three different heads used, distillate, kerosene, and the high compression gasoline head.
rustyfarmall
09-28-2004 17:14:22
If the original repair was done by a reputable shop, (sounds like it wasn't) then usually the number is stamped somewhere on the outside of the head. Look it over good.
george md
09-28-2004 17:50:56
 Re: Identify M head-#'s welded over in reply to rustyfarmall, 09-28-2004 17:14:22
Rusty, Looks like a poor shade tree job and it's clean , nothing on the outside or any where else.
george
