crankcase drain plugs
Kevin Brooks
09-29-2004 09:59:51
Can anyone tell me if there's any cooling system drain plugs in the crankcase/engine block of a '51 Farmall M? I'm trying to clean out the rust and scales inside - of which there's plenty - but don't know the best way to get at all of it. Any suggestions?
CRUSADER
09-29-2004 21:54:35
 Re: crankcase drain plugs in reply to Kevin Brooks, 09-29-2004 09:59:51
There should be a petcock on the left side of the engine, between the governor and the carb. Either that or someone put a plug in there. Have also used this more than once to drain the engine and block for winter.
Jim
The Red
09-29-2004 10:30:35
Plug is just left of the carburetor below the water jacket cover.
rustyfarmall
09-29-2004 13:07:48
 Re: crankcase drain plugs in reply to The Red, 09-29-2004 10:30:35
That plug may or may not come out. Some do, some don"t.
