Long neck vs. short neck radiator// cap??
Brian in NY
09-29-2004 11:07:21
I need to buy a radiator cap for my 51 H
They sell long or short neck (pressurized) caps, and I am not sure what one I need.
How do I tell the difference?
Thanks in advance!
rustyfarmall
09-29-2004 13:10:41
 Re: Long neck vs. short neck radiator// cap?? in reply to Brian in NY, 09-29-2004 11:07:21
I don't think there is but one "correct" cap for your H.
Brian in NY
09-29-2004 11:29:02
Sorry I wasn't clear....I am aware I need the pressurized cap but do I need the long neck or the short neck....or how do I figure this out? Thanks
CNKS
09-29-2004 15:08:32
 Re: Long neck vs. short neck radiator// cap?? in reply to Brian in NY, 09-29-2004 11:29:02
You said it was pressurized, but I missed that, sorry--I didn't know there were two caps, the parts book does list two 67448DD, and 356710 R91. There is also a gasket 352639 R91 listed for 67448DD, I assume it raises it, but I don't know. I have a cap I got from OEM Tractor parts, the handle did not clear the grille, I just bent it up a little, that number is 67448DD, also.This is a guess,since 356710R91 is the latest cap that should be the correct one, if Case-IH still has it.
little john
09-29-2004 11:52:42
I'm not sure I have a good answer, but I found that the cap on my "H" is short and scraped the paint. I had to saw a piece off of it to get it to clear the top of the grill. I am glad to have the idea of getting a longer neck cap and will check with the auto part store.
CNKS
09-29-2004 11:09:15
On a 51 the radiator is pressurized. The changed occurred sometime in the early-mid 40's.
