Super A 3pt hitch conversion
Patrick B.
09-29-2004 13:35:35
My local IH dealer does not sell anything that will hook up to my '48 Super A. No real surprise to me. They do offer a $450 kit (NOT installed) that will make my tractor able to accept a standard 3pt hitch implement. Does anybody have any expierence installing and/or using a conversion kit? Will I still be able to use the implements that I have now without a lot of parts swapping? If I don't convert the tractor where do I find implements to fit the unusual factory setup I have on the tractor now, in particular a bush hog and a rear scrape blade.
TIA (Thanks In Advace)
Merlin
09-30-2004 00:40:26
 Re: Super A 3pt hitch conversion in reply to Patrick B., 09-29-2004 13:35:35
Do you have access to a torch and welding machine? If so, you can build a 3 point hitch for under a hundred dollars. I"ve built a few of them and have never had any trouble. Then you can use a rear bush hog. Then it is an easy job to convert your rear tool bar to a 3 point set-up to handle your ridgers, middle buster, and whatever other implements you may have that are 3 point.
