Re set timing on farmall a after gov. removed
Don the plumber
09-30-2004 12:25:14
Pulled the govner on my farmall a gave to my local tractor guy to rebuild it while i was gone my father rolled my a out of the way and that moved things out of time how do i set things back into time thank you in advance for any help you can give me
Gauger
10-01-2004 04:43:17
 Re: Re set timing on farmall a after gov. removed in reply to Don the plumber , 09-30-2004 12:25:14
I'm assuming that the governor pinion was removed? This is the part with the helical gear and flyweights on it. If so you need to first find top dead center on number one piston as previuosly stated for timing the magneto and then match the two timing marks on the cam gear teeth with the single timing mark on the pinion gear tooth. Then install the magneto. If you can't find the two marked teeth on the cam gear you are probably not at TDC on #1
Dave560
09-30-2004 18:37:50
If the tractor was moved while in neutral, the timing won"t change.
Geoff NY
09-30-2004 17:10:23
The govenor has nothing to do with timing just put it back on and go.
Lee
09-30-2004 17:32:34
 Re: Re set timing on farmall a after gov. removed in reply to Geoff NY, 09-30-2004 17:10:23
The gov gear drives the mag or distributor so it must be meshed in time with the cam gear. It has nothing to do with valve timing but much to do with ignition timing.
scotty
09-30-2004 12:56:25
Don, Remove your access cover for your flywheel behind the oilpan. Find your timing mark on the OD of the flywheel, its a very fine line and may take awhile!When you find it mark it with a white marker. Remove your sparkplugs and have someone slowly crank the motor while you have your finger over the #1 cylinder. When you feel your finger being pushed away by the compression stroke, come up slowly on your timing mark on the flywheel until it lines up with the cast marker on the access cover. At that point install your mag so that rotor lines up with the #1 plug wire.
scotty
