184 Lo Boy Hydraulic Problem
JBlavl
10-01-2004 05:01:20
Recently my dad did some work on his 184 Lo Boy. The work included draining the transmission oil (which is also used by the hydraulics it appears). When he got everything back together he filled with oil and the tractor drives around great and all but the hydraulics do not work. Is there a trick to these after you put it back together? Do you have to prime the pump or something? Any help would be appreciated. Thanks
Josh
John M
10-01-2004 13:10:16
 Re: 184 Lo Boy Hydraulic Problem in reply to JBlavl, 10-01-2004 05:01:20
Did he put Hytran in or gear oil?have to use Hytran.
