overhauling H
bhb
10-01-2004 06:14:42
I have run up a stump on overhauling my H. I would like to use the stepped pistons (firecrator?) with 3 7/16 over bore. I cannot find that combination of kit, due to the valves being 5 5/16. My question would be powerwise which would be better the stepped pistons or the overbore? It looks like I will have to sacrifice something. Any help is most appreciated.
Thank you, Bill
Jim J
10-02-2004 09:43:46
 Re: overhauling H in reply to bhb, 10-01-2004 06:14:42
I have rebuilt several H's. Email me and I will help you find out what parts you will need for your rebuild.
riverbend
10-01-2004 12:33:37
Why don't you buy the pistons and sleeves seperate from the valves if you want to keep the same head ?
When I measured the domes on the fire crater pistons, they were only about 21ccs, about the same volume as the head gasket. The 3 7/16 overbore also gives about 23ccs. If you want to get more power, find a high compression head (#8043). The change in volume is over 50ccs.
Better yet, go with the 3 7/16" domed pistons and a later model gas head- the calculated compression ratio goes from 4.3:1 to 6.5:1. Also, have the cam reground to 0.240" lift. It made noticeable difference on my H.
Greg
MagMan
10-01-2004 10:45:23
Hi Bill, You must be talking about a complete motor kit I take it.That would come with valves? I have been running M&W high domes in my H for the last 30 years with one ring job And a crank that was turned 40 thousands when they put the pistons in her I have worked the dog sh#$# out of her and never have had a problem. That may be on smaller motors never heard that on an H or M I know that you want to keep your Rpms down becuase thats what they were made for.I sell motor parts let me know if you need anything . JON
bhb
10-01-2004 16:48:37
 Re: overhauling H in reply to MagMan, 10-01-2004 10:45:23
contact me
MagMan
10-01-2004 17:52:48
 Re: overhauling H in reply to bhb, 10-01-2004 16:48:37
And How would I do that??? H4magman@wmconnect.com is my email JON
EricB
10-01-2004 08:48:18
I have a 1941 w4 (same engine) I was advised by several sources not to do either. The crater fire pistons raise the Hp to about 35 but the extra stress on the crank can lead to bigger problems, especially if the crank is already "tired".
