574 Parking Brake Cable
Ret
10-01-2004 06:41:15
How difficult is it to replace the parking brake cable on an International 574? What need to be done to fix it?
CEB
10-01-2004 10:01:09
 Re: 574 Parking Brake Cable in reply to Ret, 10-01-2004 06:41:15
The parking brake is actually a band that goes around a shaft inside the tranny. A cable hooks to the band and when you pull up on the lever it tightens the band around the shaft. You can adjust the cable, but if its already adjusted all the way, then you are going to need to replace the fiber band in the tranny. What happens is that operators forget to disengage the parking brake and run the tractor with it on, thus tearing up the band.
To remove the band, you will need remove the transmission top cover. this requires removing the seat assembly, 3 point arms from the back, and the fuel tank. You also have to loosen up at least one fender to get enough room to pull the fuel tank since the fenders bolt to the tank. There are several electrical connections and hydraulic lines that need to be disconnected also. The band is a pain to remove as there isn't much room to work in there. Overall, it can be done if you have some time and patience.
