Farmall C, H, Spindle diameter
AC
10-01-2004 07:13:18
Anyone know the front tricycle pedistal spindle diameter or the wheel bearing I.D. on an H and on a C? I am trying to build a set of 5 bolt hubs fpr pulling, and I have to find a bearing. I can use either a C pedistal or one off of an H. It isn't 1", by chance is it? THANKS, AC
ronneeeeee
10-03-2004 00:02:01
 Re: Farmall C, H, Spindle diameter in reply to AC, 10-01-2004 07:13:18
check out the spindles of a 300 utility..im heard they bolt roght up?????
charlink
10-01-2004 08:59:19
Inside wheel bearing on an H spindle is 1.377 inches and the outside diameter is .940. These sizes may be a few thousandths large but it is better to be able to remove material than add it!!
