valve rocker on A
craig Smith
10-02-2004 14:16:58
just adjusted the valves on my A and it made a big difference in performance. I noticed when I adjusted the #4 exhaust valve that the rocker was loose on the shaft more so than the others. I guess the bushing is going bad. Will I do any dammage to the shaft if I continue running it, or not to worry. Thanks, Craig
El Toro
10-03-2004 05:52:24
 Re: valve rocker on A in reply to craig Smith, 10-02-2004 14:16:58
Hi Craig, Are you getting plenty of oil to the
worn rocker? I would pull it to see if the shaft is rough. I would replace that worn rocker too.
Hal
