Question on front wheel brg seals on a H.
DT
10-03-2004 07:52:15
Hello, I just bought a set of front bearing kits for my Farmall H. The felt that goes behind the rubber seal seems to be too big to fit in the hub assembly. Anyone had this trouble before? Also should I oil the felts before I put the hub on? Another question, the kit did not come with the cups that the rubber seal rides in. My IH dealer said they are no longer available, I havent found any on here either. Any information would be greatly appeiciated. Thank you.
John in Ct.
10-03-2004 19:43:19
 Re: Question on front wheel brg seals on a H. in reply to DT, 10-03-2004 07:52:15
I have IH kit # 361294R93 that I didn't get a chance to install yet on my Farmall H (Still in box). It contains 2 bearings, 1 oil seal, 1 gasket , 1 retainer and instructions.
Roger WI
10-03-2004 19:28:58
DT, I just bought the complete set from the Case IH dealer a couple months ago and it came with the complete set of bearings, gasket, seals (rubber and felt), and the cups that go inside the wheel casting the the seal rides on. My felt seal fit tight also, but I got it together. I ususally oil the felt seals, but maybe some others may want to comment. Roger
CNKS
10-04-2004 18:57:48
 Re: Question on front wheel brg seals on a H. in reply to Roger WI, 10-03-2004 19:28:58
They are dust seals, seems to me that oil would attract more dust.
