H temp gauge and thermostat
jeffrey
10-04-2004 12:51:28
after replacing the temp gauge in my H i realized the engine was not warming up at all.
So i checked the thermostat and it was stuck wide open.
I replaced the themostat with one from the dealer. Now it runs a bit warmer but the gauge never makes it into the green.
I was mowing in 70 degree weather at full throttle in 1st gear chopping some thick stuff, there was not that much load on the engine, but i still think it should come into the green.
Now when i bought the gauge the dealer said i had my choice of 2, the original type or one that was about 20 cheaper that if i was not worried about retoration detail, would work just fine.
I am thinking maybe the new gauge is made to work on newer sealed systems with coolant and run at a hotter temp.
I would be a lot easier to figure out if they would just mark the degrees on the gauge insted of cold, run, hot....
and ideas?
aitch
10-05-2004 02:31:16
 Re: H temp gauge and thermostat in reply to jeffrey, 10-04-2004 12:51:28
My Owners Manual says the pointer should be at the low end of the green when running on gas. Sid.
CNKS
10-04-2004 18:14:37
Too cold, I wouldn't worry about it, too hot is a different story. The gauge for the non-pressured system (63783D) has a green area of 130-160 degrees, pressurized (67135D) 170-220. You can also buy generic gauges with numbers on them.
e-manhunt
10-05-2004 09:06:32
 Re: H temp gauge and thermostat in reply to CNKS, 10-04-2004 18:14:37
How do you tell the difference between pressurized and non-pressurized -- by the fit of radiator cap?
jeffrey
10-04-2004 20:18:46
none of those part numbers look like the one on the gauge I put in. How do I tell if its a pressure or non pressure system. I thought they were all non pressure.
I want the gauge to be correct for 2 main reasons. I am not always the one running the tractor. Two I think an engine that runs at operating tempature is more effciant and produces less sludge in the crankcase.
MarkO
10-04-2004 14:14:40
Sounds right on the money to me. When I am not working her too hard, I would be worried to see it in the green.
