Rough running H
Jeff G
10-04-2004 15:06:08
I have an H with a loader and use it almost daily, After a rough day it has not really run well. It spits and sputters and backfires through the carb. I have tried setting the carb with the screws but no help. I took it off cleaned it up, check points plugs and cap is fairly new along with wires. I am going to check the float but don't really know how to set it. Any help or ideas. I thought the screws should be screwed all in and out 1.5 turns then set from there.
John in Ct
10-04-2004 19:36:55
 Re: Rough running H in reply to Jeff G, 10-04-2004 15:06:08
I am no expert but did have the same problem with my H. It turned out to be a spec of dirt in the carb. I think the float height is 1 27/32" measured with the top part of the carb. up side down (float bottom now float top) and the gasket in place.
wuteverworks
10-04-2004 18:50:58
the ole man down the road a piece had the same issue,happen to be a bad plug .even though the ones he had to replace wern't a month old.easy to rule out.
riverbend
10-04-2004 18:41:52
Try changing the points and resetting the timing.
QWE
10-04-2004 15:15:21
Check the fuel filter.
Does adding a litle choke help?
MagMan
10-04-2004 16:28:35
 Re: Rough running H in reply to QWE, 10-04-2004 15:15:21
It might be a little water in the gas also. JON
