140 with 1000 loader - HELP
Mark T
10-04-2004 19:03:56
My lift cylinder had a coupla pinholes in it so I popped it off and put a Chief cylinder on..it is a very close match. The problem is I must have air in the system and I don"t see a bleed valve anywhere.
Heck, I can"t even tell when/if the darn thing is full.
I didn"t loose that much fluid in the transition. The bucket is very jery and I"m getting some out the breather after I collapse the cylinder(s) and shut her down.
Any help would be appreciated.
thanx
Hugh MacKay
10-05-2004 02:53:40
 Re: 140 with 1000 loader - HELP in reply to Mark T, 10-04-2004 19:03:56
Mark: If you raise to full height and lower that loader several times the air should all come out. Are you sure the system has plenty oil. I presume the tractor would have additional resovoir with loader added. Changing a loader lift cylinder is a high percentage of the oil in that small system.
Any hydraulic system with hoses to both ends of lift cylinders, gains a sizeable resovoir within the cylinders themselves. Make sure you have lots of hydraulic oil in system. It is as important as blood in your veins, at least being low will have same effect on pump.
Ida Red
10-07-2004 17:10:10
 Re: 140 with 1000 loader - HELP in reply to Hugh MacKay, 10-05-2004 02:53:40
Hey Hugh when are you coming down to pick up that 140 Loader we talked about 4 weeks ago or does it go to the other guy? Red
Hugh MacKay
10-07-2004 18:14:24
 Re: 140 with 1000 loader - HELP in reply to Ida Red, 10-07-2004 17:10:10
Red: If you have a buyer, let it go. I am very busy right now, and don't have time to deal with it.
