uc 135 fits ?
QT
10-04-2004 19:40:53
friend of mine gave me a motor for my H but this is no H motor looks the same . what does it fit?
Stan(VA).
10-05-2004 05:11:38
 Re: uc 135 fits ? in reply to QT, 10-04-2004 19:40:53
'U' designations were typically given to stationary power plants (ie: motor on a baler). They were named for the relative size U2, U4, U6... which corresponded to the C113, C152, C248 motors like were used in the C, H , M tractors. The castings were slightly different to acct for the starter motor mounting from the opposite way, but were similar enough that you could put a U2 on a C with one missing bellhousing bolt. About the time the Super and numbered series tractors came out they started naming engines with their size as 'C-123', so what you might be looking at is an industrial or power plant version of the C-135 engine which would be similar to a Farmall 404 engine.
"Plink, Plink"...
Stan(VA).
