Need 340 Utility Wiring Diagram
Charles C(MO)
10-05-2004 07:41:49
Recently aquired a 1958 340 International Industrial Utility Tractor (FEL and trencher).
Wiring looks like someone threw a pan of spagetti under the hood!
Tractor converted to 12 volt alternator and has what looks like three sets of wires! All the same color, just to make it interesting!
Can someone send me a wiring diagram or tell me a source for wiring harness? Not looking to restore like original, just want to keep a working tractor working.
Thanks from central Missouri,
Charles
HobbyFarmerJim
10-05-2004 22:55:24
 Re: Need 340 Utility Wiring Diagram in reply to Charles C(MO), 10-05-2004 07:41:49
Charles, Is it a gas or diesel? I hav a IH Blue Ribbon Manual with many Wiring Schematics, I can scan the needed page and email it to you. Post your email and I will send it to you.
Don Russell
11-09-2004 20:24:59
 Re: Need 340 Utility Wiring Diagram in reply to HobbyFarmerJim, 10-05-2004 22:55:24
Jim e-mail is drussell44@charter.net
Thank you
Don Russell
11-09-2004 20:22:18
I just bougght an IH 340 Utility and am in need of wiring diagram also...some idiot cut the wires
and stripped some out...i would appreciate it jim if you could e-mail a diagram.
Tractor was made 7.22.F if that helps any.
Paul_NJ
11-04-2004 20:54:05
Hi Jim
I just happened to read this post, looking for the same thing as Charles. I recently purchased a 1958 International 340 Utility. And I have to rewire mine totally. If you still have that wiring diagram, would you email me a copy as well?
Thanks alot
Paul
Craig Beatty
12-23-2006 17:22:52
 Re: Need 340 Utility Wiring Diagram in reply to Paul_NJ, 11-04-2004 20:54:05
I am in need of a wiring diagram for a Farmall 340 row crop that I am restoring. Could I get a copy also?
It would be a huge help! Thanks..
Charles C (MO)
10-06-2004 05:41:13
Thanks for the response.
340 has C135 gas engine.
E-mail address:
chalcoatney (at) netscape (dot) net
Charles C (MO)
10-06-2004 06:43:02
 OOPS! in reply to Charles C (MO), 10-06-2004 05:41:13
Make that:
charlcoatney (at) netscape (dot) net
