Grease Points
Andrew Betzner
10-05-2004 17:12:45
I have a Farmall H and I was wondering if I can just use regualar old multi-purpose grease for the grease zerks for If i should use something special.
Gordon
10-06-2004 08:44:03
 Re: Grease Points in reply to Andrew Betzner, 10-05-2004 17:12:45
Plus I have one on each front wheel dust cap. Is this correct for a 49 H?
Gordon
rustyfarmall
10-05-2004 17:25:36
Pretty much anything you can find at your farm store or even wal-mart will be just fine.
Jeff In Ontario
10-05-2004 17:19:18
I use regular grease on my H. Be VERY careful when greasing the clutch zerk that you don't over-do it and have slippage.
Jeff
Dave D
10-06-2004 09:16:03
 Re: Grease Points in reply to Jeff In Ontario, 10-05-2004 17:19:18
Hey Jeff. In the event some reader of this forum might have been bone headed enuf to overgrease his clutch zerk on a 240, what's the symptom? Like can't get the clutch to engage and freewheel the drivetrain? And -- just supposing now since nobody I know could ever be THAT dumb -- what would be the cure and does it involve a split?
I...uh...have a buddy who would really like to know! Thanks.
Andrew Betzner
10-05-2004 17:35:35
Good deal, thats what I figured, thanks for the tip on the clutch zerk, there isn't any others that I should worry about over filling is there? Also, does anyone know about how many total there is, i don't need to know where they are i'll find them all eventually, i was just wondering if anyone had a number, thanks!
riverbend
10-05-2004 19:38:48
 Re: Grease Points in reply to Andrew Betzner, 10-05-2004 17:35:35
Don't over grease the water pump and pick up an operator's manual.
rustyfarmall
10-05-2004 17:51:11
Let me think on that, if it's an early H, there will be one on the PTO, one on top of each rear axle, one on top the steering shaft just forward of the steering wheel, another on the steering u-joint under the hood plus one on the bushing where the shaft goes through, one on each end of the clutch shaft, one on the water pump(one or two shots here), and one on the front of the tractor. I think that's nine if I counted right. Yours may not have one on the PTO, but you may have two on the water pump.
Dick Davis
10-06-2004 06:00:32
 Re: Grease Points in reply to rustyfarmall, 10-05-2004 17:51:11
rusty how about the replaceable zerk on the distributor?
rustyfarmall
10-06-2004 08:45:31
 Re: Grease Points in reply to Dick Davis, 10-06-2004 06:00:32
I forgot about that one, may have missed some others as well. It's always good to have others checking up on me.
