560d 14' disk
Scotty
10-06-2004 09:51:03
I am looking to buy a disk and I have found a jd rw style 14' wheel disk. I have a super m and a 560d. How will these tractors handle this disk. The soil is pretty heavy clay. Thanks for the replys Scott
VernMN
10-06-2004 17:18:30
 Re: 560d 14' disk in reply to Scotty, 10-06-2004 09:51:03
10 foot is max for the M, and 14 would be pushing the limit for the 560. A 12 foot would be the best match for it.
TP from Central PA
10-06-2004 15:51:02
I think it would handle it power wise..... ..You might want to look into dual hubs and duals to put the power to the ground IMO.
ed1
10-06-2004 14:19:35
14' is a little big. Tire size and weight are the biggest factors. An 8' or 10' is a better match. Also newer disks pull harder than old disks. Larger blades and sharper cutting angles.
Hugh MacKay
10-06-2004 13:20:07
Scotty: I agree with captain, in some conditions the 560 will handle the 14 feet. There are more situations where it will not than will. In fact I had a 12' disk that would stop a 560 anywhere. A good disk will require 1.25 hp per blade, and weight added to the tractor, to go with it.
captaink
10-06-2004 09:58:37
I had a JD BW 13’ 9” disk (which is a fairly light disk) that I pulled with a 560 gas tractor. In corn stalks it worked fine in third gear (which had the heavy tillage third gear) but in plowed ground it was too much of a load for it. Where I live we have a silty loam soil primarily with some clay subsoil. I would think that a 560D with the heavy tillage third gear would handle it a bit better. If it has the faster third gear, you might have some issues in the softer soils.
Hope this helps.
