Super C 12 Volt System
Robert Hodge
10-06-2004 22:05:15
Can anyone direct me to a company that sells 12v conversion kits for my Farmall Super C?
Hugh MacKay
10-07-2004 18:55:43
 Re: Super C 12 Volt System in reply to Robert Hodge, 10-06-2004 22:05:15
Robert: The guys are right, go to Bob M's wiring diagrams. Mounting the alternator on your Super C is easy but has a couple of tricks. Weld a plate 5/16 x 2.5 x 6 inches right on top of generator mount. Weld tabs on top of that for mounting alternator. Secondly, go to an auto scrapyard and get a double pulley from a V8 Olds or Buick. By using the outer pulley this allows you to place alternator back just enough to clear flare on engine block.
If you wish send me an e mail, I have a good photo of an alternator mounted on a Farmall 130, I can send you.
Kendall
10-07-2004 09:39:07
Search this site for wiring diagrams by Bob M. Hardest part will be adapting the generator bracket to hold altenator. Change coil, light bulbs. The starter will spin at about 140,000 rpm on 12V so dont keep it engaged too long or you might let the smoke out of the wires.
gwb
10-07-2004 05:16:35
Link
