Will John Deere Schwartz WF work on Farmall M ?
MM_TX
10-07-2004 16:56:18
I located a Schwartz WF 6 bolt hub off a older John Deere. Im going to look at it this weekend maybe I can find serial nos and will take pix & measurements. How hard will it be to fit up?
Were all 6 bolt the heavy duty ones?
Will the stearing gear arm work? Mounting holes probably will be different. Any help on what to look for and what to expect would be appreciated.
wayne peterson
10-09-2004 14:16:08
 Re: Will John Deere Schwartz WF work on Farmall M in reply to MM_TX, 10-07-2004 16:56:18
The wide front will be the same, but you will need a mounting bracket for your series tractor.
rustyfarmall
10-08-2004 06:38:52
I would assume that the actual axles, spindles and hubs would all be the same, however, I would bet the mounting brackets and such are totally different. By the time you get everything modified so it will work you will probably have a bunch of time and money into it. I believe you can still purchase a brand new wide front for an M from Schwartz, seems like I heard around $800? Don't quote me on the price.
