Starting a 460 which hasen't ran in years
GooseCreek Farm
10-08-2004 03:33:19
Just purchased a Farmall 460 (gas) which has not ran in about nine years. It is not set up. Other than change all the oils is there anything else that I should do before trying to start it? What about putting something in the cylinders to free up the rings? I would appreciate your thoughts/comments.
Redmud
10-08-2004 06:01:03
 Re: Starting a 460 which hasen't ran in years in reply to GooseCreek Farms, 10-08-2004 03:33:19
Don't have anyone standing beside it when you crank it. dirt dobbers sure like to build their condo's on the front side of the fan blades and pulleys.
Redmud:
Okilahomatractorrebuilder
10-08-2004 07:38:29
 Re: Starting a 460 which hasen't ran in years in reply to Redmud, 10-08-2004 06:01:03
Redmud dodginng the mud dobbers is half the fun of these old things. Also dodging what ever is stored in the exhaust.
rustyfarmall
10-08-2004 05:16:05
You will also want to thoroughly clean the gas tank. That old gas and varnish in the tank will come back to haunt you if you don't get it all out. Wouldn't hurt to clean and rebuild the carburetor also. Before cranking the engine, remove the spark plugs, and squirt some auto trans fluid in each cylinder, and then crank the engine over slowly, by hand if possible.
catmandoo
10-08-2004 05:48:24
 Re: Starting a 460 which hasen't ran in years in reply to rustyfarmall, 10-08-2004 05:16:05
also need to check the points,probably rusty also.
