wiring 1941 Farmall M
docrob2001@yahoo.com
10-08-2004 20:45:54
there is a screw holding a connector on the distributor housing and the same on the distributor cylinoid ....is there a wire between them????looked at a wiring diagram and can"t tell...any help is great...
Thanx
Rob
Bob
10-08-2004 20:51:10
 Re: wiring 1941 Farmall M in reply to docrob2001@yahoo.com, 10-08-2004 20:45:54
If your tractor is hooked up as original, (+) ground at the battery, the power wire from the ignition switch connects to the (-) post on the COIL, and a short wire goes from the (+) post on the coil to the terminal on the distributor.
10-08-2004 20:52:46
 Re: wiring 1941 Farmall M in reply to Bob, 10-08-2004 20:51:10
Thanx was assumin this but wanted tocheck this is new to me and ....well you know
Thanx
