Super C wiring schematics?
terryj
10-09-2004 00:28:34
Seen that link for the Cub wiring is there anyplace out there where I could see one for a Super C? Not sure if the generator is working or not. Tester says 6 volts across the battery with lights on or off but the tractor stops if take one of the battery cables off. Is it only altenaters that will keep a moter running with one battery cable off? Know I was told this once you could check an alternater this way it will keep running without a battery cable on. I know nothing about generators, think before my time or at least not old enough to remember them.
JBlavl
10-11-2004 05:57:41
 Re: Super C wiring schematics? in reply to terryj, 10-09-2004 00:28:34
If your C has a magneto pulling the wire off the battery trick will work. If you have a distributor it will quit regardless of your generator.
little john
10-09-2004 04:30:02
Link
Bob M. has generously made these wiring diagrams available. There is no diagram for a C, but maybe the H diagrams will be of help. Copy and paste the address and look for the index page. I'm sure others will come along with more info for you.
