Lubricating sleeve seals for installation
BillWV
10-09-2004 17:27:45
YTers,
My Super C rebuild is coming along. Hopefully install the new sleeves in the coming week. The I&T manual says use soap to lubricate the sleeve seals for installation; is soap the best thing to use?
Thanks,
Bill
El Toro
10-09-2004 17:49:50
 Re: Lubricating sleeve seals for installation in reply to BillWV, 10-09-2004 17:27:45
Hi Bill, I used liquid dish detergent on my sleeve seals and never had a leakage problem.
Be sure to remove any rust, scale or dirt from the block where these doughnuts sit. Good Luck,
Hal
BillWV
10-09-2004 19:01:54
 Re: Lubricating sleeve seals for installation in reply to El Toro, 10-09-2004 17:49:50
Thanks, Hal.
Clean-up looks to be a challenge on this one. There seems to be a pound of mud down in the cooling jacket. I'm assuming most of it is Stop-Leak; the radiator was butchered up.
Bill
El Toro
10-10-2004 04:47:57
 Re: Lubricating sleeve seals for installation in reply to BillWV, 10-09-2004 19:01:54
Hi Bill, Removing the dirt, mud, rust and scale
is the hardest job to do. I always had the engine
blocks degreased at a nearby machine shop. They installed new freeze plugs and cam bearings too.
I took a few into where I worked and steamed cleaned them. This machine shop has been here for
75 years and does good work. All their machinists
are ASE certified, most are master certified
Once you get that grease and dirt off
the engine is nice and clean for assembly. Very easy to repaint too. I never found any of that radiator Stop-Leak worth the effort. It usually
does what you found, stop up the radiator.
Another problem with radiators is most people do not change their antifreeze. Every
other year I think it should be drained and flushed and install new antifreeze solution. It loses its rust inhibitor and then starts plugging
up the tubes. There is some antifreeze on the market that is good for 5 years, I've never used it. I always make a 50/50 solution. It protects
down to -30 degrees and it very seldom goes below
0 degrees here in eastern MD. Ten years ago it went down to -15. Good Luck, Hal
