H vs M WFE--- same or not?
Bruce W
10-09-2004 22:14:22
Would sure like to get my wide front on my M but need a hub. Some said one from the narrow front would fit, but they are bigger in the actual hub part, than the one I have for the WFE. While perusing the local old tractor salvage yard, it became apparent to me that the hubs on an H narrow front may be tha same as the one I have on the WFE. Do I have a WFE for an H, or are they the same? All holes in the mounting plate, braces, and steering arm appear to be the right size and in the right places. Any help is appreciated. At any rate, I still need a hub and a clamp & pin for the adjustable axle. Incidentally, there are no WFE parts left in the yard I was in. H or M. Thanx much an' hav a gud'un BW
Lop
10-13-2004 14:06:28
 Re: H vs M WFE--- same or not? in reply to Bruce W, 10-09-2004 22:14:22
I have the parts you need for the farmall M wide front
lop
10-13-2004 20:41:02
 Re: H vs M WFE--- same or not? in reply to Lop, 10-13-2004 14:06:28
can help send me a email I can help farmall parts
located in Louisiana
Bruce W
10-13-2004 19:34:45
Lop, That may be great, depending, of course, on where you are and what you need. Let me know & we'll see if we can work something out. I am in northeast Colorado, about 55 miles NE of Denver, actually closer to Cheyenne Wyoming. Thanx an' hav a gud'un BW
lop
10-12-2004 20:27:39
Farmall M wide front .I may have the hub & parts you are looking for.
Geoff NY
10-10-2004 05:39:14
The M is an inch or so wider (bolster, rails, etc.) so you would have to replace the pivot that bolts to the bolster. Usually would be easier to find the correct front end.
