Tractor Splitting Equipment
Steve in Indian
10-10-2004 03:50:21
Although I grew up in an IH dealership, I'm relatively new to the old tractor hobby and I'd appreciate some information. I have a Farmall 300 that needs a new flywheel ring gear. Can anyone tell me where I can buy the stands for safely holding the two halves of the tractor when splitting it?
Thanks,
Steve in Indiana
MN Charlie
10-11-2004 10:55:59
 Re: Tractor Splitting Equipment in reply to Steve in Indiana, 10-10-2004 03:50:21
Steve,
I have designed a tractor splitting stand that is quite simple and it works very good on Farmall tractors and it will even fit other tractors that have side frame rails. Send me an E-mail and I get you some more information, charlieu@smig.net
lee
10-10-2004 18:49:44
the best system, albeit not the cheapest, is an overhead gantry system with one or two trolleys on the cross beam. The tractor splits almost effortlessly with each half on a trolley from above. You can split in two or more places very easily. Mine cost me $1000 and some labor erecting it. The gantry covers 12X12 floor space. I can pick and place on either trolley anywhere in the 12X12 space.
Steve in Indiana
10-10-2004 12:10:42
Fellows, I appreciate all the information. So will my 300.
Steve
Hugh MacKay
10-10-2004 10:24:46
Steve: If you have good smooth concrete floor, get yourself a pallet jack, some good hardwood pallets, a good assortment of blocking and ratchet tie down straps. You can single handed split and put back together even the big 6 cylinder diesels. The finesse you get with the pallet jack is unbelievable. I have had the entire front end of a 560 from clutch housing foreward on a pallet.
Hayfarmer
10-10-2004 10:04:17
I built split stands for my SMTA mostly from parts of an old front mount cultivator. I used the arms that carry come back from the front mount(fancy cultivator terms here) for the "A" frame to hold the front up. I used some of the threaded adjusting rods on the bottom for adjustment. If you have a tricycle type tractor it is tougher to keep it upright. On the back I built a stand with wheel similar to the one in the IT or Blue Ribbon Manuel. I used one of the cultivator wheels but it wasn't heavy enough to hold the rear properly with the TA attached to rear. I had to split the tractor again later and took it to a friend's shop. Used the A frame on the front and a 3 ton floor jack chained under the rear and that worked even better but you need cement floor. On other tractors I have split I have used a front end loader, block the back real well and remove the front with the loader. As I say a tricycle is hard to keep from laying down so you need to hook chains properly.
Buzzman72
10-10-2004 08:41:28
Dad and Grand-dad ran a Farmall garage for years, and they built some "stands" from two pair of side rails from a junked H or M...put mega-heavy floor jack under clutch housing, attach chain hoist on overhead I-beam to engine half, roll the engine half away, and attach the two pair of converted side rails, one to the engine half, one to the rear half.
farmallkid1958
10-10-2004 05:51:00
steve where do you live? I have a set you might be able to use if you don't live to far away.
Steve in Indiana
10-10-2004 08:39:30
 Re: Tractor Splitting Equipment in reply to farmallkid1958, 10-10-2004 05:51:00
I live about eight miles south of Wabash, or four miles north of Lafontaine, in southern Wabash County. Where are you?
farmallkid1958
10-11-2004 05:14:20
 Re: Tractor Splitting Equipment in reply to Steve in Indiana, 10-10-2004 08:39:30
I live east of lafayette about 8.5 mile, you can try to call me on my cell which only works about 1/2 the time where i live or leave me a voice mail and I will return your call. 765/491/6146.
Geoff NY
10-10-2004 05:35:05
Try a RED POWER MAGAZINE issue, there are ads for them there. I just jack mine up and build a "cradle" and use an engine hoist, but there are sipler ways. As to the gear, sincve you have to heat it to remove it, consider turning it around. I have done this on a couple of tractors with good results. Have fun Geoff
El Toro
10-10-2004 05:19:58
Hi Steve, You can probably buy those stands from your local automotive store or from Tractor Supply. The stands I have are rated at 5 tons
and they're adjustable in height.
You are going to need a hoist so you
can split and support the tractor and be able to safely separate the two halves. You're handling
a lot of weight so be careful, Hal
