Choosing between new oil pump or rebuild kit
Bill from Senec
10-10-2004 05:52:35
Hi, I am trying to make a decision on buying a new oil pump or a rebuild kit. What would you do??? My problem is loss of oil pressure after the tractor is getting hot. Would I be better off with a new oil pump??? Any help would be appreciated. Thanks Bill
rpg52
10-10-2004 15:45:16
 Re: Choosing between new oil pump or rebuild kit in reply to Bill from Seneca , IL, 10-10-2004 05:52:35
I had a rebuilt engine w/old oil pump and exact same problem. I bought new - 'bout choked at $300 but oil pressure meets new engine specs now. No regrets yet.
Ray
Jim J
10-10-2004 08:08:46
What tractor are you working on? I have several used oil pumps for sale.
Bob Quale
10-10-2004 07:20:39
I had the same problem, it was the bottom of the drive shaft was worn for the oil pump. Pushing side ways on the gear would show lots of side movement. A new rod was over $100. I got a new, old stock pump for $200. Problem solved!!! I know the guy has more pumps if you need one. E-mail me if you need help. I have no afiliation with the parts guy!!
Bob
magman
10-10-2004 07:06:16
I think you posted before on this problem didnt you? I say its bearings or oil viscosity break down my self. JON
Dave BN
10-10-2004 06:14:33
What model tractor is this? I put a new bottom plate and pressure regulator spring in the oil pump in my BN engine and it made a big difference. Total cost with oil pan gasket about $100. Dave.
