hydralic pump question
troubles
10-10-2004 10:15:56
I have a 1950 model m and would like to put a late model hydralic pump on it so id have live power. I did find a pump with the numbers 362175r-94 353h .Does any one know if that will work ? I have been told that a pump off a diesel wont work and I dont know what this pump is off of. thank you
DRN
10-12-2004 09:01:08
 Re: hydralic pump question in reply to troubles, 10-10-2004 10:15:56
This is part number for 400/450 gas, it will work if you file holes to mount. You cannot use 300/350 or any diesel pump.
DWV
10-10-2004 19:41:16
Thats the part # for gas pump.1950 is year front
engine cover changed.If engine # is 228082 or higher the bolt holes will line up.If lower # they
will not unless cover and plate change was made.
