NEW WATER PUMP LEAKING
GARY W FOJTIK
10-10-2004 13:49:41
BOUGHT A NEW WATER PUMP FOR M FARMALL,RUN IT FOR A WHILE AND IT STARTED LEAKING, TIGHTEN PACKING NUT AND GREASED FITTING AGAIN, AND RUN TRACTOR FOR A WHILE, STARTED LEAKING AGAIN,DID THIS SEVERAL TIMES, STILL LEAKING ,IS THERE A TRICK TO THIS?
roneee
10-11-2004 00:30:40
 Re: NEW WATER PUMP LEAKING in reply to GARY W FOJTIK, 10-10-2004 13:49:41
#1 throw new pump away #2 get an old pump #3rebuild with new seals and bearings and ih packing. you can get the seals and bearings at any bearing shop, 2 expensive from case ih. #4 install...it wont leak for 50 years. #5 enjoy.
45H
10-12-2004 14:16:14
 Re: NEW WATER PUMP LEAKING in reply to roneee, 10-11-2004 00:30:40
I'm in the process of rebuilding my H water pump as it had a cracked pulley. How much IH packing should one use?
RayP(MI)
10-10-2004 15:43:41
Can you take it back to store? Sounds like they owe you a new one! (Yeah, I know, it's a pain to take off and put on another!)
justin w
10-10-2004 14:38:51
I assume this is one of the "new production" water pumps that several companies are selling now?? if so, these are made in turkey or india, so you can guess the overall quality of these parts.
CNKS
10-10-2004 17:38:40
 Re: NEW WATER PUMP LEAKING in reply to justin w, 10-10-2004 14:38:51
I bought one of those from Steel Wheel Ranch. It had some subsitute packing in it. It leaked, using IH packing helped, but it still leaked. I bought some of the graphite coated string from NAPA, it helped but still drips, slightly. The problem in both the old and new pumps is that the nut gets loose. The shaft, etc, appears identical to the original pump, except I think the shaft is metric. I can find no reason that both the old and new pump should leak, nothing visibly wrong with them, but the IH packing does not work well in them. The tolerances in both the old and new pump, including the packing are not exactly rocket science, but I don't know why either should leak. My personal opinion is a packing quality control problem, but I have found no one else with the same problem.
riverbend
10-10-2004 18:17:29
 Re: new water pump leaking in reply to CNKS, 10-10-2004 17:38:40
I remember you writing about that earlier. It is pretty odd.
I took my water pump apart when I replaced the adjustable side of the pulley. The bearings weren't too loose, and everything else looked okay for being 60 years old. Putting it together, I used new IH packings, and it has been fine.
Greg
CNKS
10-11-2004 14:04:05
 Re: new water pump leaking in reply to riverbend, 10-10-2004 18:17:29
I dunno, maybe I have it on backwards or something.
