IH 350 Diesel Problem
superman
10-10-2004 15:23:21
My 350 Utility with Continental 193 and Roosa pump had been running well. Suddenly it began to miss as if running out of fuel.It has lots of fuel. The engine is now very hard to start, lacks power, stalls easily, runs roughly and sometimes flames and sparks come out the exhaust. Exhaust produces lots of gray/white smoke. Loosening the bleeder plug on the pump produces lots of clear fuel. Loosening each injector line in turn causes a loss in RPM, all cylinders about equally.
Has something come apart inside the pump? It was rebuilt about 1000 hours ago. Thank you in advance for any suggestions.
Tractor Dan
10-11-2004 04:44:56
 Re: IH 350 Diesel Problem in reply to superman, 10-10-2004 15:23:21
i have a 350 diesel that had similar problems mine still starts hard and has the the grayish smoke i dont know how to cure that but the flames coming out of the exhaust sounds like the pump is out of time
email me if have any questions or if you get it figured out
TractorDanP@aol.com
