h runs weird
daniel gillespi
10-10-2004 16:05:33
faremall H runs fine then just quits or have to use choke to tun it. then it makes a chuging sound. ANy help?
up red
10-10-2004 18:15:39
 Re: h runs weird in reply to daniel gillespie, 10-10-2004 16:05:33
you may want to check the tank outlet located inside the sediment bowl, mine was plugged due to dirt from the tank, also the screen on the sediment bowl, or the carb inlet filter (located on the carb where the fuel lin attaches) hopes this helps -- had the same problem with my 48 - rick
CNKS
10-10-2004 17:25:51
You have a fuel problem, anything from poor flow from the tank, to a carburetor rebuild.
