H spark problems
Dan 3588
10-11-2004 16:55:02
I have got grandpa's old H out, converted it to 12 volt, and trying to get running again. We had trouble when we parked it. I have got spark all the way to the plug. On the third and fourth cylinder, though, its missing. If I pull the wire off the plug and hold it up to it, it will hit, but with the wire on, it is dead. Any ideas?
Gary - Iowa
10-12-2004 06:36:20
 Re: H spark problems in reply to Dan 3588, 10-11-2004 16:55:02
I've had the same problem on an S-MTA. I bought it hitting on 3 cyl. with new plugs and learned that Champion plugs were notorius for having short lives in the old Farmalls. A Farmall old timer told me this and in this case, he was right.
Dan 3588
10-11-2004 19:18:50
Well, it was bad plugs. Thanks MagMan. Sometimes, when a guy gets frustrated, he doesn't take the time to think. When I switched the plugs, BINGO. Runs like a champ now. They were recently put on, they were champions, D16, I wonder if sitting finished them. I stepped up to D21s. Thanks again.
MAGMAN
10-12-2004 05:22:13
 Re: H spark problems in reply to Dan 3588, 10-11-2004 19:18:50
Your Welcome, I have had plugs bad right out of the box and some that didnt last 1/2 hour you never know. But I have been running Hs and Ms for close to 30 years and the champs always performed the best for me. My first exsperiance with a mag was a bad coil wire rebuilt it bought a nother one from and old man that switched over to dist
Had me baffeled for a day or two. But thats where I learned about Mags.A teenager with grease and oil in my blood I guess Oh lets not forget Red. JON
John in Ct
10-11-2004 19:01:18
On my H mag, the plastic thing the roter mounts on turned inside the gear it attached to so my roter was always out of phase.
MagMan
10-11-2004 17:09:38
Try replacing or switching plugs and wires or cap. See if it makes a difference. JON
