sore subject 460
Spud
10-11-2004 20:58:59
I bought a 460 at a sale last week off the owner before the sale He said it was a good tractor and that it had no prolbems had it hauled home sent to a repair shop for odds and ends the bill was over 500 dollars and the shop called me and said the torque is no good and said it will cost about 1200 to put a torque in call the previous owner he wants to give about 200 on new torque any one interested in a good looking junk 460 with a wide front and good running engine?
Stan
10-13-2004 08:37:16
 Re: sore subject 460 in reply to Spud, 10-11-2004 20:58:59
Spud
Where is your tractor located. I'm looking for a parts tractor for my 460.
Stan
Hugh MacKay
10-12-2004 02:38:46
Spud: Look at it this way, new tractor is going to cost you about $750. per hp. Used will not be much unless you invest minamum of $200. per hp. I am speaking of a tractor that will be reliable when you want it. As Kelly said you may be able to save on the labour, by doing yourself. I'm not so sure that the $200. per hp will cover the labour.
Kelly C
10-11-2004 21:20:30
My rule for buying old tractors.
Dont buy them if you cant or are unwilling to learn to fix them.
You can buy a rebuilt torque for about $500 incl all the seals if you do it your self.
Also. Unless you are going to be doing any thing heavy with the 460. No real need to repair the torque. It will work fine in high range.
Actually though $1200 is not to bad to have some one else put one in. IH wanted $1200 just for the part.
Good Luck though. I have had the same kind of luck with my sale finds a time or two. Got a geat deal on my 400. Found out why after I finnished the rear seal, clutch, TA and replaced 5 gears in the tranny. Learned alot and have one heck of a nice 400 now.
