International 504 Hydraulic Pump
Joe Vurgason
10-12-2004 05:02:44
International 504 Hydraulic Pump makes a winding/grinding noise in the pump, I think it is the main pump or the hand pump, What should I do about this noise?
THanks
Joe
Tom d.
12-13-2004 14:33:35
 Re: International 504 Hydraulic Pump in reply to Joe Vurgason, 10-12-2004 05:02:44
I beleive your it is your check valve is bad
tom
Ben in KY
10-12-2004 06:37:41
Is your fluid full and no water in it, Is the suction screen and any hydraulic oil filters clean, Could the suction line for the pump be sucking air ? If none of these are a problem then the pump might be shot and require replacement or repair.
