H engine mounting
ernz
10-12-2004 09:55:14
can a person remove the front bolster and frame rails while leaving the engine attached to trans/torque tube? in other words, do you need to support the engine if you take the frame rails off, i can see 1 bolt that appears to bolt engine to housing coming in from behind flywheel housing.
Larry Martin
10-12-2004 18:24:57
 Re: H engine mounting in reply to ernz, 10-12-2004 09:55:14
I have one setting on a stand under the clutch housing in the barn now. Makes it essy to clean up the engine and replace gaskets.
ernz
10-13-2004 04:46:23
 Re: H engine mounting in reply to Larry Martin, 10-12-2004 18:24:57
thanks for the info, i thought that was the case, the previous owner felt oil leaks and puddles were cheaper than a few gaskets and thats is what i am planning to do.
MN Charlie
10-12-2004 10:57:58
There are two bolts that hold the engine block to the clutch housing one is to the left of the starter. and the other one is inside. You have to remove the starter and reach inside with a 3/4 inch socket to remove. These two bolts are 1/2 bolts but are a lot different in length. I"m guessing that one is over 6 inches long and the other is less than 2 inches I have removed the front bolster and side rails and left the engine hang on the clutch housing many times. Just make sure these two bolts are in place first. Not a bad idea to place a safety stand under the front pulley. MN Charlie
Andy Martin
10-12-2004 09:59:06
The one coming from the back is a lineup dowel. It will not help hold the engine to the housing.
I've never done it, but you should be able to support the tractor that way. I'd put a support under the harmonic balancer.
