h overhaul question
bhb
10-12-2004 11:14:37
Are the stepped pistons and the international fire crator the same? If not what is the difference? I was thinking of the overbore sleeves and stepped pistons. With the high compression pistons would it still use regular gas? This is not a production tractor, just garden plowing and hay rides. I feel that if I sell it I would want it to be in the best condition. Any suggestions would be appreciated.
MagMan
10-12-2004 13:19:14
 Re: h overhaul question in reply to bhb, 10-12-2004 11:14:37
Ok lets try this again yes differences but the same Idea.Dont worry about going with the cheaper aftermarket. I run regular 87 octain in my SM with fire crators no problems . When I pull I run higher. Its hard to find anything thats not over bore these days. JON
captaink
10-12-2004 12:28:10
Maybe someone else has better info, but i believe the normal stepped piston has a raised area on the top of the piston that looks like the opposite of the depression in the head. The “fire-crater” had a step but also had a semi-circle area in the step that formed a “crater” in the top of the piston in the step where the spark plug is located.
I have fire-craters in my “M” and run either an alcohol blend or regular gas in it with no problems. While you have the head off, I would suggest checking the exhaust seats to make sure that they have been replaced with the hardened ones that are designed for lead free fuel.
