Degreasing
Martin
10-12-2004 14:10:02
How can I degrease a block and engine head without taking it to a machine shop. I do not have facilities to cook them, and I would like to keep the block on the tractor for now, so i can move it, we're building a new shop.
Thanks in advance!
El Toro
10-13-2004 05:12:40
 Re: Degreasing in reply to Martin, 10-12-2004 14:10:02
Hi, Try using some Dawn Power Dissolver, Spray it on and then let it soak for awhile. Then power wash with hot water. Hal
ernz
10-12-2004 18:47:46
you might try some citrus degreaser, can buy from industrial/janatorial suppliers, more expensive than others mentioned, but will melt road asphalt in minutes as well as grease, oil and some paint.
JRB IN MAINE
10-12-2004 16:51:43
castrol super clean pump up sprayer and hot water. works great can get it at wallmart $5 a gallon.
MagMan
10-12-2004 16:21:47
Ok Yes you can buy oven cleaner at dollar general,I tryed it but I did not think it worked great. How about renting a pressure washer.Hot water is a must not super hot just hot tap will work.Do you have them off? Take them to the car wash.You can buy engine degreaser at wally Mart for .88 cents a can.How about building a fire under a tub of water? Just a few thoughts JON
parts man
10-12-2004 15:29:23
Oven cleaner makes an excellent de-greaser.
AdamA
10-12-2004 18:12:20
 Re: Degreasing in reply to parts man, 10-12-2004 15:29:23
I agree. Oven cleaner works for me. I spray the tractor or desired area and let it set for a day and then wash it with a high pressure washer. I just done this to my third tractor and it has worked everytime. I spray the whole tractor and that takes care of any grease and also removes some paint.
QWE
10-12-2004 14:51:41
You need a whole colection of wire brushes
then finish cleaning with a scruffy pad and
paint thinner.
