International Model M Grain Drill
rwlmak
10-12-2004 17:10:02
I need to know what are the grain settings are. I have lost the metal grain plate that used to be in the inside of the drill. I will pay for your information.
riverbend
10-13-2004 19:15:25
 Re: International Model M Grain Drill in reply to rwlmak, 10-12-2004 17:10:02
Lets try again -
If you have an MF, look at abebooks(dot)com and search for mccormick grain drills. I have a manual for an MF. It shows the seeding rate adjusted with a small gear that is set against a cone shaped cluster of (drive, I suppose) gears. That manual has a chart for setting seeding rates, etc.
rwlmak
10-14-2004 10:25:08
 Re: International Model M Grain Drill-Thanks in reply to riverbend, 10-13-2004 19:15:25
Thanks for the response. I have bought two books via the Internet, but they will take at least a week to arrive, and I need the settings today. Could you be so kind as to tell me what the settings are in the book for wheat? I am planting fifty pounds or quarts per acre. What size sprocket will I need. I would like you to call you, but this is a public forum, and as such, I do not want any one's privacy compromised.
rwlmak
10-15-2004 22:10:20
 Re: International Model M Grain Drill-Thanks in reply to rwlmak, 10-14-2004 10:25:08
Thanks Greg for taking the time to send me the specs that I needed. They were exactly what I needed. I've had these drills only a couple of years and always used a guide that was on the lid of the drill, The lettering was getting light but could still be read,until I went to get to drill ready for seeding and the lid of the drill blew open during the winter and the lettering was completly gone. So I Thank You for helping me out. Wayne
riverbend
10-14-2004 19:14:43
I hope that this is not too late. I know how it goes sometimes, timing is everything. I spent all day digging potatoes and did not look at the computer.
This might be a little hard without the illustration. Gear C moves up and down when the latch B is set in the notches to select the correct gear on the cone shaped cluster. Sprocket A looks like it runs the chain to the feed shaft. There is also a cover on the feed mechanism in the bottom of the hopper.
If you ahve an 8 tooth sprocket A, the most you can plant is 42 Qts. / acre with gear C set by latch B in notch 10. If you have a 16 tooth sprocket A, setting latch B in notch 4 will give you 48 qts./acre and notch 5 will give you 54 qts./acre. In all of the above cases, the cover on the feed mechanism goes on the left side (it appears to be the wider side).
Good luck with your planting.
Greg
rwlmak
10-15-2004 17:31:48
 Re: International Model M Grain Drill-Thanks in reply to riverbend, 10-14-2004 19:14:43
Many, many thanks! That was exactly the information that I needed. I am very grateful. Now if you could just make in rain. It was supposed to rain here by now.
