what engine do I have?
awutay
10-12-2004 20:07:21
I have a 41 H. The farmer I bought it from said he ran gas in it. So have I. I finally checked the serial number against the parts catalog and the serial number suffix is X3 (kerosene). I looked through the engine parts list section and can"t see any parts in the H engine which would distinguish gas from kerosene.
Is there any difference between the kerosene and gas engine? Should I return to running kerosene if the X3 designation is correct?
CNKS
10-13-2004 08:20:47
 Re: what engine do I have? in reply to awutay, 10-12-2004 20:07:21
Buy a parts manual, it will tell you which parts you need. The head, pistons, sleeves, mainfold,etc are different. It can be converted to the X1 series (gasoline) if you wish. No, don't run it on kerosene, use gas, it will be fine.
Dr.Evil
10-13-2004 10:51:39
 Re: what engine do I have? in reply to CNKS, 10-13-2004 08:20:47
Even the valves were different in the kerosene & distillate engines because the combustion chamber in the head were different depths.
GeorgeH
10-13-2004 05:32:48
My understanding is that the X1 engine (gas only) has higher compression. $.02 worth..... .....
