I have a Farnall F-14 with serious 11-40 tire prob
Nicholaus Sowde
10-13-2004 16:56:50
I have a Farnall F-14 with serious 11-40 tire problems. The side wall on one tire is showing the intertube about 5 inch worth. Is there anything I can do to save tire. Thanks
MM_TX
10-14-2004 14:25:23
 Re: I have a Farnall F-14 with serious 11-40 tire in reply to Nicholaus Sowder, 10-13-2004 16:56:50
Carrage bolts through a large boot from the inside to outside. Ugly but works.
Andy Martin
10-14-2004 05:31:51
There is nothing you can do for the tire.
A side wall boot will not stand up. I have proven that for myself after being told the same by others.
You could boot it if you just let the tractor sit and don't drive it much.
John M
10-13-2004 17:47:22
Mine were in just about the same condition,I just trashed them.I hated to d oit cause new 11-40 werent avavilable at the time and the 9.5s were expensive,but a lot less headaches!
Farmall Power
10-14-2004 08:48:40
 Re: I have a Farnall F-14 with serious 11-40 tire in reply to John M, 10-13-2004 17:47:22
you can get a pic of belting and put that on the inside and bolt it on, it isn't the nicest thing but it works.
FP
