Cylinder pressure on an H
Pat B in Mich
10-14-2004 18:57:16
What's is the norm on cylinder pressure for and H motor can't seem to find it in the manuals I have.
Thanks to all who helped with My H missing under load. It was a combination of retiming the valves and adjusting the carb. Did a comp test I have a little leak but not missing under load like it was. I still think new rings would help.
Hermit
10-15-2004 16:41:26
 Re: Cylinder pressure on an H in reply to Pat B in Mich, 10-14-2004 18:57:16
According to the GSS-1356 manual, 120 psi for gas engines, 95 psi for distillate engines and 145 psi for gas engines with fire crater pistons.
Allan in NE
10-14-2004 20:28:06
Hi Pat,
Ya can't take this one to the bank or anything, but it seems to me that the H only had a compression ratio of around 6.5:1, so that ought to put 'em somewhere in the 100-110lbs range if I remember right.
However, you need to look for uniformity more than anything else.
Glad ya got 'er straightened out,
Allan
