clutch plates
johann
10-15-2004 14:46:15
While installing, pulling and reinstalling the engine in our 606, we finally discovered the noise was coming from the bolts that hold the flywheel to the crank. They were hitting the clutch plate. So now, is there a back and front to the plate? How do you decide which side faces the engine . Please instruct. Thanks.
Aces
10-15-2004 15:39:40
 Re: clutch plates in reply to johann, 10-15-2004 14:46:15
Johann yes there is a front and back, the drive member should have spring loaded hub and that hub is off side and needs to go to the back if you hold it in the flywheel with the hub to the flywheel it should not set flat and that is what the csrews are hitting.
