MD Farmall MW hand clutch
The IH Kid
10-15-2004 16:47:03
I have a chance to buy a MD thats been sitting for sevral years engine is stuck but its all there...I would like to try to restore it....My first question is what is a M&W hand clutch??? its on the tractor and ive never seen one before...could some explain???? Also Where can you find parts for the tractor??? Ive been looking and there is a lot of pieces i cant find....
Thanks
The IH Kid
farmallkid From ONT.
10-16-2004 15:49:10
 Re: MD Farmall MW hand clutch in reply to The IH Kid, 10-15-2004 16:47:03
When you say kid i dont know if your 10 or my age 16. Is this going to be your first tractor? If it is, I would just go with a gas M for your first tractor, They are cheaper to fix and easier to maintain, The diesels are a bit harder to maintain, And alot of money to fix. Since its seized up, then it could have a cracked head, then you get into the big bucks, I know a guy who has a SMDTA, he has $12000 into the engine, and another guy has one, he quit on it, cause it was takin to much $$$$. I'm not trying to scare you away from it, i'm just telling you it could get expensive. Just wondering if your from ontario, I saw an add in the ontario farmer paper, It was an MD with an M&W.
The IH Kid
10-16-2004 18:24:25
 Re: MD Farmall MW hand clutch in reply to farmallkid From ONT., 10-16-2004 15:49:10
No im 21 i already have 2 Hs and a M and a F-20 I bought the MD today and another M...The MD is loose and from what ive seen so far look as if its run in the past few years....
knauff
10-15-2004 17:37:59
The M&W hand clutch kind of gave the tractor "live" pto and hydraulics. By pulling the handle, the tractor stops moving and the pto and hydaulics still work. Can't shift the tractor w/o the foot clutch though. Parts new for the clutch mostly have to be made, but there are some used parts floating around. My M&W is indespensible picking corn and baling hay(maybe because a NH 570 baler w/thrower is a little too much). Good luck and have fun!
knauff
10-22-2004 16:26:26
 Re: MD Farmall MW hand clutch in reply to knauff, 10-15-2004 17:37:59
Check out Vintage Ads. I posted everything I have on the hand clutch. Good luck
