International A plow
JonT
10-16-2004 16:13:59
Does anyone know the model number of the mid-mount disk plow for the Farmall and International A with the Pneumatic lift?
gene b
10-18-2004 05:05:11
 Re: International A plow in reply to JonT, 10-16-2004 16:13:59
Seen some this summer at shows but none had a # to identify but there is a manual out for all the attachments for the pneumatic lift all att and shows where everything goes. My plow parts manual is just for moldboards.
Hugh MacKay
10-18-2004 04:09:06
Jon: When you say mid mount, could you clarify that just a bit. I don't know a lot about disk plows, however I don't think mid mount, will physically work with plowing disks ahead of rear wheels. I do have a parts catalog 85-PO. It's called tractor plows built since 1939. The only disk plow it lists for A and SA is the A-147, which is basically a rear mount. Having said this, it does hitch to drawbar mounted on front side of final drives, very close to middle of tractor. This is precisely the same way A and SA mold board plows hitch to tractor. Remember also this book I have may not cover all plows built in that era.
