Farmall M Hydraulic Pump Seal
Marlin M '51
10-16-2004 18:31:11
How do I remove the drive from the pump so I can replace the shaft seal on the hydraulic pump on my M? I replaced the lower transmission seal and was able to unscrew that portion of the drive with a hammer and punch, but I don't know how to hold the shaft on the pump so I can unscrew the drive member. Thanks for the help.
Wayne Swenson
10-16-2004 22:22:21
 Re: Farmall M Hydraulic Pump Seal in reply to Marlin M '51, 10-16-2004 18:31:11
You have to remove the pump from the Lift-All housing and put a flat piece of steel in the oil pickup hole so it will hold the gears from turning as you unscrew the drive coupling. You should replace the gasket at the same time as the seal.
Marlin M '51
10-17-2004 04:28:15
 Re: Farmall M Hydraulic Pump Seal in reply to Wayne Swenson, 10-16-2004 22:22:21
Where's the oil pickup hole located?
