Need help with brakes on my 806!
806 D
10-16-2004 19:59:19
I am experiencing poor braking pressure on my 806 tractor. Pedal used to come right back to life when I started tractor, now it has quite abit of travel and poor brake response. If you hold your foot onto the pedal, it does seem to push back after a few seconds, but as soon as you let off, it goes limp again. Any ideas?
Thanks!
ChadS
10-17-2004 08:53:12
 Re: Need help with brakes on my 806! in reply to 806 D, 10-16-2004 19:59:19
Our 856 had the same problem, there is a seal in the brake that can either leak internally, or leak outside the brake housing, fixed the seal and still did it,, found a pressure relief valve in the master cyl, an oring was split and was bypassing the full fluid pressure to the brake cyl. Hope this helps, ChadS
