what to do with U4 engine ?
J Muehring
10-17-2004 08:11:40
Im thinking about selling my U4 engine at a consinment auction. Its not runing but is loose and H4 mag has spark. No visible cracks in block or head and manifold is real good. Missing gen,starter and clutch. Should I leave engine in one unit or disassemble and auction off all the seperate parts. Appreciate everybodys two cents.
rustyfarmall
10-17-2004 14:05:03
 Re: what to do with U4 engine ? in reply to J Muehring, 10-17-2004 08:11:40
Where do you live? If you are not too far away I may be interested in the complete package. Which head does it have? the high compression gasoline head could be worth quite a bit, Not much demand for the distillate head, so if the head is the distillate head, leave it on the engine, and sell it as a unit. If it is the gasoline head, separate them. I think the engine block will be worth more with the pistons, crank and rods all as a unit.
J Muehring
10-18-2004 14:22:09
 Re: what to do with U4 engine ? in reply to rustyfarmall, 10-17-2004 14:05:03
Im at Hannibal Mo. I guess its a gass because manifold does not look like kerosen or distillit.
